Flush Or Not To Flush
My boats going into a marina, its usually kept on a trailor and i flush the outboard after every use. There doesnt seem to be any facility to flush the engine whilst its moored, how long can i leave the engine before it requires flushing? Christ just read that back and im confused so God help you lot! Yellow antifoul CAN YOU GET IT????
theduke
26 Jan 2002
peel isle of man
dont panic.its not going to furr up or rust that quickly. i flush at the end of each season when i lift out.no problems after 8 years ,then again maybe manx water isn't as salty as your water. i'm sure someone will know
castaway
31 Dec 2001
Solent
uk.groups.yahoo.com
I had the same dilema when i had an EBoat with a 6hp johnson O/B, and I found that a bucket lowered over the transom so that the prop sat in it in its "up" position worked well. Of course you had to vertical lift type bracket and a hose nearby to fill the bucket once in position.
I would run the O/B for a few seconds in neutral. Prob did no good at all but made me feel better.
Nick
andyball
1 Jun 2001
Having seen the damage/blockage caused to some engines.... (blockage mainly on little 2's and 3.3's, to be fair, but it doesn't take much to hold a thermostat open on any size engine), I flush the new engine every time (on a marina berth), but if you can't, you can't.
Is there no way to get a flushing attachment on while it's moored ?
Most people seem to do it once a year, but the outboard workshops get a lot of business......
