Gypsyjoss
My Sadler has a Stuart No2 Engine seacock held down by three nuts and washers onto bolts or studs. I had a bit of seepage from under the fitting and solved that by tightening up the nuts, one quite a lot. That was 3 years ago.
I've just scraped the hull down to an epoxy finish. I decided to remove the seacock, better to regrind the taper valve, and reseal it and am astonished to find that it is flush fitting with no spigot through the hull. The sides of te hole through the hull appears to be epoxied.
The seacock is in good condition, and my first thought is that if such a fixing arrangement has lasted since 1985 then a dose of Sikaflex will make the joint leakproof for another 20 years. However, one of the bolts is longer than the other 2, and one can be moved slightly. I'm concerned that they might be pulling through the fibre glass - I do have bad dreams!
Does anyone know if these had an external plate, with the bolts held captive such as Blakes seacocks do?
My other seacocks are Blakes, and though the spigots can be seen externally there's no visible sign of the fixing bolts and plates.
Cheers
Cheers
