Bodach na mara
I have been very interested in this thread and it has produced several good links (which I have bookmarked) however the introduction of the light output in lumens issue was not completely sorted.
Lumens per watt is not the whole story. You need to consider the spatial distribution from the source as well. An incandescent bulb (in a simplified ideal case) radiates equally (almost) in all directions roung a point at its centre. A short fluorescent tube does much the same. Reflector lights redirect the light into a smaller solid angle, thus an incandescent lamp emitting 400 lumens does not light a work surface 2 metres away from it as well as a reflector lamp at the same place with a beam spread of 60 degrees emitting 100 lumens.
As LEDs emit within a fairly narrow cone, even at low lumen values they provide better illumination than incandescents or flourescents of equal lumen output.
