Floating containers - ever seen one?
tudorsailor
12 Jun 2005
London
zebahdy.blogspot.co.uk
My question would be is how dangerous is a floating container? Unlike a power boat or a Vendee Globe racer, I wonder if a container would do much damage even it hit directly at 7-10kn
If one looks at the Crash Test video - https://youtu.be/bRhcXBtmPQs they found it quite hard to make a hole in the boat to start the test which I find quite reassuring
In reality, you are most likely to make a glancing collision. Would this really hole the boat?
TudorSailor
Irish Rover
5 Feb 2017
Türkiye
TudorSailor
The Irish sail training ship Asgard sank in 2008 and it was generally speculated she hit a container https://www.irishtimes.com/news/asgard-ii-sinking-report-released-1.865672
CLB
18 Jun 2013
All those containers of BMWs that washed up on the beach must have floated there.
jimbaerselman
18 Apr 2006
Greece in Summer, Southampton in Winter
www.jimbsail.info
The facts of observation sjow a significant number of awash containers.
Yes, I've seen one nearby.
Another time my nephew hit one with his keel doing six knots or so in a 40 foot boat. Immediate external inspection showed 5 to 7 degrees skew aft; internal inspection showed floor lifted aft of keel, some movement, and some salt water leakage.
A 40 minutes return to base was possible within an hour. Luckily, most of this in smooth water.
ianabc
21 Oct 2003
BC Canada
In BC deadheads
are more of a problem than floating containers.
Dead heads floating logs, vertically floating logs pack force as they move vertically with the swell.
My marina neighbour lost his 28 foot fibreglass sailboat to a dead head.
Rowed ashore with his dog, lucky that he was close to shore as the sinking was sudden.
NormanS
10 Nov 2008
In BC deadheads
Do they float vertically because of stones embedded in the root ball? The logs that I see generally float horizontally.
oldmanofthehills
13 Aug 2010
Bristol / Cornwall
A friends boyfriend almost certainly drown due to his boat hitting a shipping container in the Irish Sea. The investigation concluded that nothing else could have sunk his boat that fast and prevented any message from him and crew, or deployment of liferaft. Boat never found so must be informed estimate.
Maybe a chance in a million but pretty nasty and having seen debris washed up from containers I think they mostly dont sink straight to bottom without trace
pagoda
19 May 2008
Scotland
I saw one off selsey bill a few years ago while out paddle boarding, it appeared to be about a foot or so below the surface. Certainly a hazard to any boat.
Maybe not to a paddle board! Something large and made of steel 1 foot below the surface I do NOT want to meet while sailing in poor light.
Never seen one myself and really don't want to.
lw395
16 May 2007
Sounds like a best guess to me.
It could have been any sort of flotsam, or something else entirely like structural failure, e.g. if the keel falls half off and opens a big hole in the bottom of the boat.
Speculation.
These things are so rare that no pattern emerges.
oldmanofthehills
13 Aug 2010
Bristol / Cornwall
It could have been any sort of flotsam, or something else entirely like structural failure, e.g. if the keel falls half off and opens a big hole in the bottom of the boat. Speculation. These things are so rare that no pattern emerges.
I believe a long keel boat so no keel fall off, but I can only go on the accident assessment at the time of the loss (1976), and that declared probability of hitting shipping container as the only thing to rip a massive enough hole to sink in seconds. So some authority regarded lost containers as a known risk. I suppose it could have been one on her majesties submersible things but that was not the speculation then and there are even more containers lost nowadays
Seajet
23 Sep 2010
West Sussex / Hants
My worry about hitting an awash container is maybe gashing a hole in the bilge side if hitting a corner, maybe more likely hitting it square on.
It's well known when looking at secondhand fixed keelers, fin or twin, to look at the aft upper end of the keel and the hull around it; if the boat has been run aground into a hard seabed at high speed ( personally I'd count that as anything above 4 knots with the mass/ velocity involved ) - there could be severe damage, and I think the same or worse applies to a boat offshore in waves hitting a very big heavy steel box, I'd be worried about the keel getting kicked up and piercing the hull.
Lift keelers with a vertical lift plate and ballast bulb like my Anderson 22 would probably suffer the same fate, there is a tufnol ' crash strip ' at the aft end of the keelcase ( unlike any other lift keeler I know ) but I wouldn't fancy trying running into a container full pelt.
Lift keel boats with swinging plates or multihulls may fancy their chances of skipping over a container but I don't think the odds are in their favour.
Elessar
10 Jul 2003
River Hamble
Just updating my opinion on this: not a threat as they all sink, and mostly fast. Some might float for a bit if they contain timber or flatscreen TVs with a lot of polystyrene packaging; but they all go down in the end.
Anyone ever seen one or heard of one?
Thanks in advance.
Nope. I did see a huge wooden cable drum c 20ft diameter floating off Malta and that was likely to stay floating. But never a container.
May be folklore but apparently you can fit a valve to make them sink more quickly for a trivial sum but no one does it. Anyone know if that is true?
JumbleDuck
8 Aug 2013
SW Scotland
Her Majesty's submarines sank a couple of fishing boats in the Irish Sea in the 70s ... perhaps this was another of their victims?
Seajet
23 Sep 2010
West Sussex / Hants
I only remember a Contessa 32 getting knobbled - a periscope or other mast through the hull, nuclear propelled, is probably a recipe for a Bad Day - and maybe one fishing boat dragged backwards and sunk by a sub - nationality never dertermined but Sean Connerys' lot were busy in those days ?
The fishermen from Portpatrick were scathing about RN subs after one surfaced oblivious in the middle of a fishing fleet.
A book very worth reading is ' Hunter Killers' by Iain Ballantyne, quite illuminating , and amusing at times.
NormanS
10 Nov 2008
What bit of "buoyant contents" do you not understand? :rolleyes:
Elessar
10 Jul 2003
River Hamble
What, apart from air that would be removed by a valve, can go in a shipping container that is more buoyant than the weight of the container ? Polystyrene in packaging is much reduced now. I doubt any container is buoyant when full of water, if I’m wrong it’s certainly not many.
dom
17 Dec 2003
Celutex insulation boards?
