wipe_out
Just switched to AGM batteries and the manufacturer specifies float voltage of between 13.5V and 13.8V.. My charger is a Promariner Protech-4 30A charger which I believe is the US version of a Sterling charger.. The manual claims it is compatible with AGM and also claims a float voltage of 13.5V but when I connected it up today and measured the voltage I found that the float voltage was 13.3V..
How critical is the float voltage and will running at 0.2V below the manufacturer spec have any ill effect on the batteries?
