Flex teak strips for interior
weaver_fish
10 Aug 2005
Does anyone manufacture stuff like the Tek-Dek product for cabin use? I was wondering if there was an interior only product that might be cheaper that the outside deck products.
Cheers for any info
If it's your cabin sole you're talking about, this was my post to a thread about that a few months ago. If you search for 'flooring cabin sole' you'll get the entire thread:
I relaid my soles last winter using a teak/holly effect laminate (almost like formica) from Robbins Timber, around £80 for 8' x 4' sheet. My 32-footer needed 1.5 sheets (although they don't supply half sheets). Check out: www.robbins.co.uk/mar_cabin.htm
It seems very hard wearing, looks great, has good grip even when wet, cleans easily and needs zero maintenance. Applying it was pretty straightforward, once the technique is learned. You'd need use of a router. Should you go ahead, feel free to PM me for fitting details.
If you prefer to be more traditional, Robbins also do a proper veneered teak/holly laminate, minimum thickness 6mm, which looks much the same. Costs around twice as much as the other stuff.
