Whiterose
I want to take my headlining down and put battens up and screw the headline mounted on board.
My question is how do I fix strips of batten to Hull?Whats best to use.
I also want to replace my electric panel with a tidier wooden panel mounted to the Hull presumably the same would apply although the Hull has probably been painted.
Advice on glueing or fibre glassing in would be much appreciated.
On another point is it possible to block ingress of water from inside ie a fitting leaking without unmounting the fitting.
Many thanks
Rich
Many thanks
Rich
