Tim Good
I have post previously on this topic and since had my storm boards made and delivered. They are 8mm polycarbonate.
View attachment 66629 View attachment 66630 View attachment 66633
Here is thing and some facts:
1. I don't want them permanently on as they look naff. Just for big passages or if we get caught out and see a huge weather system coming that we can't dodge.
2. As previously advised I'll put a layer of 1.5mm neoprene around the edges to make a reasonable seal and they may double up as double glazing to prevent condensation since we like to sail in high latitudes.
3. The existing aluminium frames have screws all the way around so I removed one and drill it through to see if I could use maybe 4 of these to fix the window by putting a bolt though it. See pictures.
View attachment 66631 View attachment 66632
So what do you think? My problem is that if I drill these out then when the boards are off I'll be left with holes to fill / cover somehow. Also attaching the boards with 4 bolts per board could be a lengthy job.
Has anyone got suggestions for a smart way to fix them which will be fast, effective and no look hidious from the outside when the boards are removed?
