JeffBoath
Recently bought an Elizabethan 31 that I'm delighted with, she's currently on the hard before "lift in" in a couple of weeks. I've tried to fit the prop today and found that the drilling in the prop shaft which takes the spilt pin, doesn't line up with the hole in the retaining nut? Should I shim the nut (if I tighten if up it it only reveals half a hole as it effectively screws on beyond the ideal place) or should I re-drill the shaft with the nut hard up against the prop (it already has 2 holes drilled in it from previuos efforts).
