Fitting Transducer thro' steel hull
Ecartar
18 Dec 2001
Fitting Transducer thro\' steel hull
Need to replace my ageing Seafarer Echosounder and have removed old transducer from my steel hull. This was secured in a vertical steel tube welded in position thro' the hull.
Has anyone any thoughts/recommendations on the best to buy and whether one type or the other would have a transducer to fit into my existing housing, perhaps with minor modifications.
I also need a speed log and the same problems exist, although here I appreciate that I shall need to fasten thro' the hull with a new hole & fitting.
Should I go for a dual display or separate units. Ive heard the NASA range is very good.
Thanks,
Re: Fitting Transducer thro\' steel hull
I got a NASA Clipper Duet e/s & log last year. The e/s is suspended in a plastic tube glued to the inside if the hull, but sure it could be adapted to fit your existing steel tube. The tube is then filled with oil to form a complete liquid link from transducer to sea.
The log is very easy to fit, altho a hole is required!! I am happy with the performance of these instruments, and believe they represent value for money. Contrary to some opinions on this site, I found NASA very helpful & extremely prompt on delivery.
Hope this helps.
brgds
Mike
