Fitting teak plugs
where do you guys get the best teak plugs from if you'r not cutting you'r own please?
S.
one makes one`s own with a Stanley plug cutter from No 6 > No12
Not if you've got the Axminster kit - you use the plug cutters in the kit, then they'll fit the holes you drilled with the matching drill bits.
Scotty - there's no sense trying to buy ready-cut plugs since there's not much chance of them being a good fit in your holes.
As a traditional wooden boatbuilder just retired after nearly 50 years in the trade, I have always used standard flat bits to bore the countersink hole (much cheaper alternative than those already mentioned and with the advantage that the bits can be easily sharpened). A piece of masking tape acts as a depth guage. I use a tapered plug cutter in a pillar drill to cut the dowels so they tighten as you tap them in with a dab of Cascamite or similar glue.
Hi all, thought I should return to say thanks for all the advice.
In the end I bought the Axminster set and a pillar drill which worked perfectly :)
I've experimented with a few methods over the years.
FWIW the best plug cutters I've found are these Veritas ones:
http://www.axminster.co.uk/veritas-tapered-snug-plug-cutters
And I usually use these drill and hole combined sets to drill the holes:
http://www.axminster.co.uk/disston-screwdiggers-with-hex-shanks
I've used the combined 'Stanley' ones in the past but I was told by one toolshop that they aren't available any more.
Bought a set in Lidl(or Aldi) last year.Still waiting for anopportunity to use them:)
I've the No 8 set of those. With a tapered plug cutter you shouldn't need to glue the plug in. I sometimes use a little varnish if the end result is to be varnished anyway. Remember you may want to get it out again!
The only drawback of a tapered plug cutter is that without a pillar drill the plug often breaks when cutting. Not a problem if you have a lot of off-cuts!
The drill part is also brilliant for countersinking. And never creates a rough edge.
One caveat. It's important that the plug doesn't touch the screw once tapped in. So I often trim the end off with a chisel before inserting.
Hi all, I've just taken delivery of a lovely new piece of teak which will be used on the boat shortly. Now that I have it though I realise that I have no experience fitting those little teak plugs and also lack the confidence to give it a bash on my shiny new teak. I think I'm happy with the cutting off and sanding part, but the drilling has me worried in case I make the hole too big or too deep etc.
Do I just use a normal drill bit? What's the best way to avoid going too deep? from what I understand I just use varnish to "glue" the plugs in?
Thanks all, I know someone on here will be able to explain the process :)
I have a plug cutter and the drill to go with it. take the plugs from offcuts and they fit fine. only real difficulty is getting the plugs to go in straight.
