cambscot
Active Member
I'm considering methods of making the fuel supply to the diesel cabin heater a bit more permanent, as it's currently using a 10l plastic water carrier wedged in the cockpit locker.
Rather than fitting a second tank, I'd like to use the same tank for both the engine and heater. The easiest solution would be to fit a T-piece in line with the current fuel take-off, and feed that to the heater. However, there is always the chance that, if fuel is low, you might end up with a warm cabin but no engine fuel.
To prevent this, I was considering putting a second fuel feed out of the side of the tank, perhaps a few inches above the bottom, so the heater can never drain the tank. Is this a viable option, or have I missed something obvious?
Is there any easy way of retro fitting a second fuel feed out the tank without having to open it up somehow?
Am I just overcomplicating it, and I should fit a T-piece and just watch the fuel level?
a
a
