A
Anonymous
Guest
I am on the point of fitting a holding tank macerator. My tank and sea cock fittings are 38mm. The macerator input is 38mm and the output is 25mm. The chandler tells me that I can use a Vetus adaptor (cut as required) to match, which sounds OK. The present arrangement is a plastic Tek Tank (one year old) pumped from the top by a Henderson hand pump, up well above the waterline in a loop, and back down to the sea cock. The top of the holding tank is more or less on the waterline. It would be convenient to fit the macerator just above the tank and take the macerated output straight down to the sea cock without looping up over the waterline. Is there a disadvantage in doing that? Are there any tips or suggestions anyone can make...? Peggy /forums/images/graemlins/smile.gif
