tcm
Re: eh?
bottom dead centre is always 180 crank degrees opposite from top dead centre, innit? - it doesn't matter what the other cylinders are doing, or even if there aren't any. So wiggo is right, imho?
With the cyl head on, you can't see the valve open or shut. But you can see the little pushrod come up, and then go down, halfway between is TDC near enough, so 180 degrees near enuf the other side it'll be properly shut and the valve clearance can be set with crank thereabouts - the clearance has to be accurate, the crank position can be anywhere nearish BDC cos the cam is circular at either side of BDC.
