RobWales
Hi All,
Recently bought a 24' cruiser which has had a brand new 4.3MPI engine fitted due to frost damage on the original motor.
With the engine having run less than 20hrs from installation I feel now is an ideal time to fit an hours run meter as the boat does not have one fitted as standard.
However where would I take the positive supply from? not sure I want it from the ignition as ignition may be switched on but engine not running....hence false hours reading....so where would I get a supply that only supplies when the engine is actually running?
Alternator perhaps?
Thanks, Rob.
Alternator perhaps?
Thanks, Rob.
