ghostlymoron
I'm replacing an N-type Male Connector for RG58. The old one had the centre pin soldered on - is this necessary?
N connectors are designed to be soldered.
You MIGHT get away not soldering a new one, but it's certainly not to be advised.
But if re using a second hand one, there's really no choice as the pin will be full of solder. It's nigh on impossible to clean all the solder out.
You CAN re use it by soldering.
12V soldering irons are rubbish, get a gas powered one, they work outside okay in all but the indiest conditions.
I normally use these http://cpc.farnell.com/1/1/19733-n-crimp-plug-rg58-vn10-2051-vitelec.html no messing with solder, reliable and fast.
Vitelec stuff is OK, but that will be designed to be crimped with two fairly expensive tools.
It's important to seal the coax against damp getting in, I prefer the clamp type plugs for amateur use.
You could - but you might easily over heat it and then the solder goes all funny and doesn't flow.The reasons I want to avoid soldering are:-
1. Difficulty of getting enough heat in the joint on a windy deck
2. Ability to re-make the joint if I get problems in future
Could I solve no. 1 by using a gas blow lamp to heat the centre pin then inserting the (tinned) centre conductor and touching some solder on it.
I've decided to carry a spare to get round difficulty no. 2
