mainshiptom
The control panel power light does not come on when rest of lights do, manual says do not start but does not say what is wrong.?
Anyone got any idea so.
It ran all day yersterday with no issues once we wanted to switch off it ignored us so we switched 12 volts offHow old is it ? Older one ( I had one once ) are direct seawater cooled .Dissimilar metals mostly AL alloys fizz up and leak .
Have you checked all the connections , be careful around the capacitors , from memory manual mentions shock hazard with theses .Rest should be ok .But it’s the low voltage side i would check out first .
When was it last fired up ?
Newer ones I believe are indirect cooled with a HE , and the “ coolant block “ corrosion issue gotten around .
Fuse is good and control panel lights up and starter turns but looks like it switches the fuel pump off and does not want to go!On mine there is a small 500 milliAmp (or something like that) on the back of the control panel, I had to replace once. Might be the issue.
Will try that! ThanksHow good is its starter bat ?
From memory it’s got a “low bat “display , but the fuel solinoid might be V sensitive and not working first if the V drops .
Can you charge it up or stick a volt meter over it ?
now battery fully charged 14 voltsHow good is its starter bat ?
