ithet
Is there a better solution than using small chocolate block type connectors for the very small wires as used for NMEA0183 multicore cable?
Solder & heatshrink.
Wago connectors - pennies from eBay
http://www.ebay.co.uk/itm/20-x-2-WA...al_Components_Supplies_ET&hash=item5d3d2db507
Never seen those before but they look really good, thanks for the tip.
More choice and cheaper here:
http://cpc.farnell.com/jsp/search/b...wago&Ntx=mode+matchallpartial&getResults=true
I don't know what you're doing, but you aren't linking to the jpg.
I made this distributor for nmea, It is fed from one GPS. Radar, DSC, comp, are plugged in the front. I can also use the extra lead to plug another GPS into the front, male or female jack seen on the right. All available from Rapid electronics (audio) for pennies.
(Why doesn't photobucket work like it used to?)
