Cardo
I'm in the process of sorting out the seriously bodged job done on the rudders on Tinkerbell. As with many other bits on the boat, the theory is good, but the implementation is painful.
The twin rudders hang on brackets using M12 x 90mm bolts. This works, but the problem is there is play between the bolts and the brackets, allowing the rudders to move ever so slightly. This causes a "knock knock knocking" that can be quite irritating in the rear cabin when there's a bit of a swell. I had hoped to improve this by using nylon top hats. I bought some 12 ID x 14 OD hats, and drilled the brackets out to 14mm. The hats fit snugly in the brackets, but unfortunately it seems M12 bolts have an outer diameter that's slightly smaller than 12mm, probably close to 11.5mm ish, maybe less (I need to buy some callipers!). So we still have play, although now it's SS on nylon, instead of SS on SS, so hopefully it's slightly improved.
Question is:
Is there a supplier that will have SS bolts that have an OD of just shy of 12mm? Or is it possible to get them made up at a reasonable cost?
Question is:
