eddystone
I think the time has come for a more systematic refurbishment of the deck. The major part is non-slip which is relatively straightforward as I'll be using Kiwi Grip. The problem areas are the fine cracks which occur mainly in the vicinity of right angles or curves. I have used Magic Ezy in the past without much success The larger ones I aim to open out with a Dremel and fill but this is impractical in small areas where there is a mass of ultra fine lines. I thought about sanding back a bit and then skimming over with flowcoat. Trouble is I don't know how to make flowcoat. What does one mix with gelcoat to give it the required viscosity?
The other problem is brown stains from bird droppings. I've tried most things including oxalic acid (Y10) without success.
