Fill or drain diesel tank
colhel
9 Jan 2011
Gillingham(Dorset) Boat Weymuff
Its likely we're going to have an extended lay up ashore. With the possibility I may remove the engine, I'm wondering if I should fill up before we get hoisted. Probably about 1/2 a tank or a 100 litres. I fear this is 6 of one 1/2 a dozen of the other type question, but I'd welcome your views.
I reckon cleaning tanks is a job that should be done every 5 years or so, its stood me in good stead when I took that approach on an old boat I had for many years, at first I had a load of trouble, nobody had been in the tanks for 40 years, I fitted inspection hatches,. Good clean and scrub, I found fairy liquid worked, traffic film remover works too, but wear gloves. I use a washing up brush on a stick to give it a good scrub, agitate the scum.
Hoover out. Dry out with paper towel, I left mine in the sun when there were out of the boat, the times I did it in the boat I put an electric fan heater in there for a couple of hours to really make sure its all dry.
Then put the fuel back in through one of those water trap filter funnels.
I have used 25 Litre 25L Jerry Can Water / Fuel Container Food Safe Tamper Caps or Tap Caps | eBay
BTW Col at risk of the whole operation un ravelling...depending on your maintenance history....while the motor is out....replace all skin fittings and seacocks, all morse cable, all bilge pumps, exhaust hose, all jubillee clips, new bog, etc, go right through the boat chucking a couple of £1k's of chandlery at it, you can reset the boat elec and mech stuff for 15 years. I've done it twice on old Huntsman and its well worthwhile.
The boat is quite well sorted in that regard @burgundyben with a lot of new hardware from previous ownership. The main reasons for a refit are cosmetic, but due to restricted access, the engine and engine bay look extremely scruffy and even though running top notch, could do with an all over inspection. With a few non boaty projects on the go I am a bit concerned I'm taking on too much as it is
