NigelCraig
Firstly, I don't understand the relationship between painting the hull and gelcoat (above the waterline). As gelcoat is self coloured, is the concept of painting strictly for older boats where years of weathering and "erosion by polishing" means painting is the only option? BTW, I saw a 1970 Nic 32 a couple of weeks back with quite a few little blisters (max 1cm but mostly smaller) in the paint above the bootline - could these just be defects in the top layers of paint?
Other main issue is repairing a teak rubbing strake, of roughly 5cm by 2cm section - it's lost a big splinter at the aft end which runs through one of the screw holes. I have a short section of teak but the section profile is marginally too small to replace the whole end bit with a scarf joint. Could I just replace part of the end section? i.e. with a scarf joint for the vertical join but a butt joint longitudinally - obviously that means a lot more exposed join for water to get into. (you can see my carpentry skills are non existent!) And what sort of glue to use? I envisaged just unscrewing part of the strake and supporting it, enough to get a tenon(?) saw in to cut a piece out. Any idea how long to clamp the join before I can screw it back?
