Fender socks
Cut off, melt tops to prevent fraying. Fix through hole at top of fender with cable tie. Cut off end of cable tie, almost invisible. I've used ASDA fleece lined ones but works out expensive, nearly £3 per fender!
I'll tell you at the end of the season. But a friend who is very knowledgeable in textiles tells me it is basically the same material as the dedicated fender socks.
