Thanks for the suggestion, the needle adapter just doesn't fit well enough. In fact I ended up bending it. It's something in between the really thin one and the next size up.It’s hard to see from the photo but could it be like a football valve where you insert a thin inflating needle attached to your pump?
Yes it is .... if I poke it with the metal "needle" valve it lets out the air. The tapered ones we have a standard car kit ones are too wide. You can buy lots of packs but no guarantee you'll get one that fits. Shame they aren't all standard fittings. This is just the first of quite a few we have inherited with the boat.... the start of many puzzles I think.If you poke a needle one in gently can you feel a spring valve? If so use the tapered fitting that fits the hole and seals around it. You can then use the car pump but you have to hold it firmly in place.
Thank you.I'm not 100% as the photo isn't that clear but it looks like a majoni valve to me in which case they are useless imo. If you purchase the correct screw in fitting it barely works and your best bet having freed up the spring is to rig up something that depresses the spring while sealing against the fender. I bought a selection of fittings on eBay for a couple of quid and rigged something that worked. Alternatively just take it to a garage and hold the air line tight against the hole and it will have enough pressure to force the valve open.
When Iwas a kid we used to put two thicknesses of cotton handkerchief between the garage air line and the valves on our bikes or footballs, to form something of a seal. Had to be quick though, before the garage man spotted usTry just placing the end fitting of the pump hose over the mouth of the fender valve - no special hose to fender adapter. - and make as good a seal as you can between the two. Some of my fenders inflate in this way. Why there's no standard valve fitting for fenders baffles me.
