Fender board options
kennyh
18 Jun 2006
Firth of Clyde / West Coast Scotland
Hi all
I’m going to make my first transit of the Crinan canal (west coast Scotland) in a few weeks and as of yet I have not taken my Jeanneau Prestige 30S through a canal.
I’m looking at options for fender boards and I could take the normal approach of using wooden boards, but I’ve come across an alternative that might be more practical / lighter for a MoBo.
https://youtu.be/Qoq2A9btBdI
In the video above they are using pvc pipe, and I looked at options and can get 68mm gutter down pipe that might do the job.
Q. Have you tried this approach - do you think it will work or should I stick to V1 and use decking boards (or similar)?
Hi all
Those will not withstand much in the way of bumps and scuffs against rough or corrugated lock walls. You really need a larger area against the fenders and more strength for when loaded between two fenders. Suggest a piece of 10mm 4ftx2ft exterior ply from wickes, cut lengthwise to make two 1ft wide planks. Fix a length of 2x2inch timber along each long edge to each plank. Drill a hold near the end of each top 2x2 to pass line through with a stopper knot. Two coats of any old leftover primer. Light and strong. Works for me.
www.solocoastalsailing.co.uk
If you have access old hardwood door , cut 150mm off jamb , drill hole each end , varnish up : perfect
