Feeding hose
Get a 10cm piece of pipe that fits nicely inside the hose you want to replace. Push 5 cm into the old hose and use a couple of self-tapping screws to secure it. Now do the same with the new hose. .This way not only can you pull/ push the new hose but you can twist it as well
That sounds an excellent idea
Without knowing your specific situation and assuming there is no existing messenger or old hose to use, then perhaps a stiff wire bent to bridge the two accessible ends, once this is through then tape a piece of twine or wire draw this through providing the messenger, then use this to draw the hose, or if necessary a heavier piece of rope to draw the hose.
Best solution I find is paying a man wot knows, money well spent but agree a fixed price job not by the hour is best. Otherwise reply #9 seems a good idea, other than cutting an access hole in a suitable place and making a cover board to close it afterwards.
Or trade the boat in....?
Flexible drain cleaner - domestic calibre. They come in different lengths. Useful afterwards for rodding out......always have one to hand!
PWG
I have just had to do this very problem fitting a new hygienic pipe for the heads to a new through hull valve. I just couldn't push and control the track of the hose. It jammed either between hull and inner lining or twisted around and disappeared beyond reach into some hidden space. I used an electricians fish tape in seconds to get through to a position to pull back a halyard tail. The halyard tail was then threaded through the pipe and tied onto a large ring spanner that then took the strain. Pull on rope and the pipe found its own way in seconds around to the new seacock position.
Steve
