If the master switch is an isolator next to the battery
Have you checked the earth return to the battery from the alternator?
I assume from your drawing that you only have one battery.
I agree you need some more fuses, situated at Stemar suggests. As the one between the isolator switch and the domestic fuse panel is only there to protect the wiring, there is no need to add up the current draw, just fuse it for the max cable rating.
No need to run the alternator B+ all the way back to the switches, that can be connected to the battery terminal of the starter relay.
The master switch is an off/1/all/2 type, i believe if no one turns it by hand it will stay in place while engine working.
I still havent connect the battery, but i have checked with multimeter (for continuity) the casings of engine/alt, engine/dyna, and dyna/alternator, and it beeps in every combination. Is there a prefered point for connecting the battery negative? The Dynastart has a D- terminal (M4 screw) but the alternator only the casing.
I added the 2 single fuseholders to the diagram
Thanks for your feedback!
Your diagram only shows a single battery, so why the 1-2-Both switch ?
Thanks for the tips! diagram updated![]()
I suggest that if the boat is kept in the water an automatic bilge pump should be connected so that it is not turned off by the master switch but separately wired to the battery with its own isolator.
If the engine is a diesel you also need a circuit for the stop solenoid.
On engines with dynastart that's usually called a stop cable![]()
You need to ensure good connections between the engine block and battery negative for the alternator and between the Dynastart D- and battery negative for the Dynastart......... I would be looking at possibly doing this by taking a heavy connection from battery negative to a convenient bolt on the engine block and connecting the Dynastart D- to the same point
Hi Vic!
I was looking today for a point to connect the heavy negative cable somewhere on the MD2B but couldnt find a surplus stud or nut. I thought of attaching the heavy -ve cable on the Alternator's holder with an M8 screw and nut, and from the same screw a shorter cable running to the dynastart's D-
Unless this idea has some error it is handy doing it this way.
.No need to run the alternator B+ all the way back to the switches, that can be connected to the battery terminal of the starter relay
