Bodach na mara
Well actually it is a NASA instrument but when I was trying to connect it up this afternoon, my wife asked who this farking company was that made the instrument that was giving the problem. Now I know I should not have bought it and that Tactic was the way to go when I invested in it two years ago. I also know that they don't really like joins in the cable but you do need to have some sort of disconnection when the mast is removed.
I tried a Bulgin plug and socket but that was too cumbersome and gave problems with a bad contact. Then I connected the cable ends with a terminal block, but that seemed a pain to reconnect each year, so I fitted a 6-pin lockable plug and socket (from Maplin) as recomended in a thread http://www.ybw.com/forums/showflat.php?C...&PHPSESSID=
(Unfortunately the images in the post have been deleted from photobucket.) Now today I connect the plug and socket, turn on and get no speed reading. Sometimes there was a bit of movement in the vane indicator, but not as much as there should have been. I took both the plug and the socket apart and the wires seem to be still connected. It does look like a connection problem. So now for the questions.
What do you use to connect this thing up? Does your system work? If so, please spill the beans and make my language less "industrial."
