Fan heater thermostat onboard?
Conachair
24 Jan 2004
London
Reckon something like this would work through a relay to control a fan heater onboard?
The thermostat built into the heater switches off at tropical and back on again at arctic :(
Are you sure the built in thermostat is really as bad as you claim.
The kit in your link requires a 12 volt DC supply and would need an external relay, rated for the current of your fan heater at 240 volts but with a 12 volt coil, to control the fan heater.
So
Why not simply use a decent room thermostat.. If your power socket is suitably placed a plug in type might do the business
I found the need for a thermostat external to the fan heater, because in a small cabin the air temperature on the floor where the heater sits can stay quite low, while the air at body height becomes uncomfortably warm because the heater just stays on until it senses that the incoming air is warm. So I fitted this thermostat and socket about half way up the bulkhead. It's wired to the socket on the left, and the heater just plugs into that. I got it at Maplin, but I don't see it in the current catalogue.
So
It is pretty awful, maybe partly because in under the chart table not much air moves. 12v is easy on the boat and a relay would be easy to sort out. I might give it a go. Lot of winter to get through yet.... :)
If you go for a room thermostat check the switching rating. You need one capable of switching 10A or more. They are available from B&Q etc for about £15.
Sledgehammer + Nut.
OK, a try putting it on a table then.
:o It's only a little boat. :o
Barely enough room for the laptop to post on here and dinner on the table at the same time. :)
Under the chart table is the only sensible place I've came up with so far to put it without major surgery and cables across the floor.
Well, the maplins kit soldered and seems to work well, just breathing on the sensor turns it on and off. Just need a relay and little enclosure and all should be a finely controlled cabin of cozy warmness :)
For the clever LX types, the spec here says
Maximum switching power:
3600VA resistive
450W resistive
Is one AC and the other DC?
Fan is 1800W, would that suffice? I make it 7.5A max.
I would be careful where you put it, or else use something like a Dimplex Coldwatch.
We used to leave a fan heater with a frost setting in the kitchen of a holiday home we owned.
One weekend we arrived to find the thing had caught fire and self-destructed. Fortunately it was on a stone-flagged floor well away from anything combustible.
:eek:
Sounds like another good reason to have a separate thermostat. Anyway, the one onboard will only have power when I'm at home.
