floebs
Active Member
OP should do some more research. The above will no where near provide enough power to get you through a winter.
If alongside you will need shore supply & if at anchor or on a mooring a reliable eberspacher/wood burner etc A dehumidifier will make it even better.
A trip to Trago Mills to purchase a couple of rolls of foam carpet underlay to lag the boat will improve comfort beyond belief.
Thanks Sandyman, you ARE my research
Thanks for the prod though, yep, I have an ebber onboard - it needs an overhaul, well, it needs putting back together and seeing if it actually works!! It came with the boat. I have a small delonghi dehumidifier, and I have a little oil filled radiator - what I'm trying to ascertain, is how much power these might need, and what alternative complementary forms of heat generation, moisture reduction, insulation, ventilation and lifestyle choices I would need to adopt to make my little floating home suit my needs. Part of those needs are a desire to shift to 'off-grid' living - so I'm researching how best I might achieve that, and if not fully, what compromises I might need to choose to get as close as I can.
There's nothing better than peoples real life advice, and I'm taking everyones suggestions as another point to look into. So, please, if you have opinions, keep 'em coming. The more that is raised, the more I learn.
