Fairline Targa 44, before i decide, hints, tip, issues?
Take down and put up the canopies a couple of times before you buy. They can be a real hassle if they are shrunk in cold weather, also there is a definite procedure to follow to get it right.
As this boat probably comes with Penta D6 and outdrives or IPS that´s where you need to put the attention. The outdrives break more then they should and the IPS are very expensive to service/repai
Read more at http://www.ybw.com/forums/showthrea...i-decide-hints-tip-issues#d3lVLdw1fKT2dFdI.99
Your words, & if you spend the money on regular servicing with a good main dealer they don't miss a beat. The reason so many outdrives fail is people cutting corners by not doing things such as changing bellows every two years without fail. It amazes me when I see posts asking if they can reuse oil etc.
Unfortunately the DPH drives fail even if you service them correct. Not all of course but way more than older Penta outdrives and Mercruiser
