Hurricane
Could you post/comment on the process of teak sanding.
Are you removing any of the deck fittings when sanding? etc...
Interesting stuff, but doesn't that sound like a solution to a non existing problem?The stabiliser job has turned into a refit of the actuator assembly not just the fin, so Sleipner can fit their new keyless tapered shafts.
Hi MapisM. I can't justify any of it on need (!) so my rationale is just that I'm interested to have the latest and greatest gear really. The simpler keyed shafts do the job though they can be a PITA to remove and I bet you would have some fun trying to remove yours after 20 years - when the female taper is encased inside a composite fin you cannot heat it up as you can with a propeller hub. So yes it is a solution to a non existent problem but that's nothing new as regards most boats/my boatInteresting stuff, but doesn't that sound like a solution to a non existing problem?
I mean, what's wrong with the the simpler shafts that always worked just fine on any boat - for almost 20 years now on mine, just as an example...?
Besides, IIRC you had the same fins size (1sqm) also with the flat ones, didn't you?
I'm asking because according to the claims of higher efficiency AOTBE, I expected that you were fitting somewhat smaller fins.
The underlying assumption being (obviously) that the smaller any bits sticking out of the hull are, the better, particularly on a P hull, but also in general.
As an aside, I fully agree that - for what can be seen in your pics - the GRP plugs look perfect. A grp hull can't get any better! :encouragement:
Hi Hurricane. The s/s fittings are being double masking taped, not removed (I didn't want the damage of removing them). The guy is using a 150mm diameter orbital sander, but as he approaches a s/s fitting he switches to a mouse sander and/or hand sandingCould you post/comment on the process of teak sanding.
Where the deck meets GRP side coaming, superstructure, bulkwarks or any vertical "wall", he just uses a piece of 3mm MDF, about 500mm long by 100mm tall and places it on its edge against the GRP. The sander then just rubs up to the MDF which protects the GRP. He actually masking tapes the GRP too, just for nice OCD ness
The caulking was 0.5mm proud where the deck was in the sun a lot. This is the new teak deck doing its initial shrink down to a steady state, where I think it will stay for several years without further significant shrinkage. The proud caulking was knifed off using one of those little handles that you slip a Stanley knife blade into, converting the blade into a sort of scraper/chisel. Removing the proud caulking was like a hot knife thru butter
The honey colour of the teak comes very quickly - as you know the grey layer is perhaps 0.1mm thick only. I'll post pics
My overall theory here is to sand the decks once, at about 18months old, to level them after the initial shrink down of the wood. I'm taking about sanding off perhaps 0.2mm off 6mm thick teak. I don't then plan to sand them every year. My thinking is they will now go several years with no additional sanding, and just cleaning
Thanks for that
Mine needs some attention and I'm wondering what to do.
Even thought of replacing it with synthetic.
I like it looking like new (honey colour) - I don't like the silver finish that the yachties seem to crave for.
My caulking is very much proud of the surface, maybe I will have a go with the Stanley knife idea.
I did all my caulking with a very sharp chisel, and it's a lovely job, really therapeutic! I managed to get a couple of continuous bits of shaved caulking the entire length of the flybridge
It's not quite up there with chopping up logs with a chainsaw, which is about as good as it gets, but it's definitely one of the nicest jobs I've done on a boat. If your boat was in Lymington I'd do it for free![]()
Mine is in Beaulieu, is that close enough !!
Sorry for the drift JFM
Haha, good point. Pretty much the same as the (albeit increasingly popular, I must admit!) AnCam....?So yes it is a solution to a non existent problem but that's nothing new as regards most boats/my boat![]()
Interesting concept. I fully agree that the only way to get meaningful results is by experimenting, so yes, I'll definitely stay tuned 'cause I'm curious to hear the differences (if any) you will see in engine load/consumption, at any given speed.At D speed there will be extra drag but Sleipner have a hunch that the lift from the big curved fin will "pay" for the extra drag at P speed by making the boat semi-hydrofoil. We might want more stern lift too and if that's the case I have the option to install bigger flaps (because I already have upgraded flap hydraulics, installed during build) or just add some Interceptors. Or even a pair of fixed interceptor blades.
Yeah, I know, I know... I was just pulling jfm leg a bit, after he posted "AnCam TM" on JTB thread...Re Ancam,
MapisM we have to disagree on this one,
Our Ancam is in the most perfect position, as if you are standing on the bow, and looking forward right down to the anker and the chain.
This is absolutely a practical solution for a real problem, more on that later in one of my own threads,
MapisM There is only one way to convince yourself how practical this is, and that is to come again onboard of BA and experience this huge practical benefit yourself![]()
MapisM the AnCam is awesome! I might have to make it my life's ambition to persuade you and read a post on here from you saying "Yup, JFM has a point, that AnCam is a darned good idea!". Think I'll have to bring it south and show youHaha, good point. Pretty much the same as the (albeit increasingly popular, I must admit!) AnCam....?
Running for cover now...![]()
Actually, jokes aside, as I recall I already conceded at some stage that it can make sense, depending on the specific ground tackle and also on personal habits/preferences.MapisM the AnCam is awesome! I might have to make it my life's ambition to persuade you and read a post on here from you saying "Yup, JFM has a point, that AnCam is a darned good idea!". Think I'll have to bring it south and show you![]()
Hi M. I'm launching Saturday am and maybe doing a few sea trials before the sleipner team heads for airport/flight back to Norway so I'll be back on berth Saturday pm I guess. Drop by if you're around in the afternoon. EME might be around (need to ask him); Jenny isn't - she's on a michelinny residential yacht chef course while boat is drydockedThe hardtop looks very good and certainly a massive improvement over the bimini on this size boat imho. All hardtops on boats this size and much bigger have a habit of looking a bit out of scale/top hatted relative to the overall boat when viewed at certain angles in photos, now't to worry about there, up close and personal it will look amazing from any angle. In Antibes over the weekend, will pop over to take a closer look if she's there. Very nice proper job in an impressive time frame. (JTB, how much longer is your platform going to take mate?)
If you fancy a trip out to sea come to shipyard ("Bleumer" yard, the only one there with a travelhoist) at Baie Des anges marina (aka Villeneuve Loubet) earlier. 10 am ish I think. Its the marina with the big (huuuge) swoopy apartment blocks, 4 miles along the coast NE-wards from Antibes port, literally the next port along the coast NE-wards from Antibes port.
You're looking at berths I hope!
