bromleybysea
I am about to fit an Airmar echo sounder transducer to my boat, a long keeled deep-draft 60's cruiser racer. The Airmar is a chunky bit of kit compared to the existing transducer, probably an old Seafarer one. There is no surface of the hull (GRP) that is "horizontal" under the waterline so I will have to fit at the turn of the bilge with a fairing block inside and out to get the transducer perpendicular to the waterline. My question(s) is as follows:
What is the best material to use- the Airmar is plastic and the blurb cautions against fitting to a wooden hull because of the risk of cracking it as the wood swells- I have some teak and thought of using that with a reasonable clearance and lots of mastic? (having spent an unfeasibly large sum on the instruments I balk at the prospect of having to buy a new bronze transducer housing)
What's the best way of fixing the fairing blocks to the hull? Epoxy? Sikaflex?? And would I be best advised to through-bolt the inside and outside blocks together?
Thanks in advance chaps- it's been giving me sleepless nights!
