Fail safe - fail dangerous
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
Last night we got back to the boat at about midnight and launched the dinghy for the 200 yard journey across to the boat. t was raining and blowing a three - fairly choppy and misty.
Not brilliant. The little Honda 2.3 fired up perfectly then as I turned around the kill cord got pulled and the end of the little red button sheared off
it is not entirely unlike this one
http://thumbs4.ebaystatic.com/d/l225/m/m2GmlZM0kwblDf4sKwBeK5Q.jpg
so we were faced with 200 yard row in the dark in a choppy loch
so not much of a safety feature then in my opinion
the Tohatsu came with a crummy little bit of plastic cam attached to a bit of coat hanger metal rod designed to prevent the operator from starting the engine in gear. One day at trent Falls on the Humber it decided to prevent starting in or out of gear
that incident happened at Trent falls - again jeopardising safety
One the biggest safety features of any engine is for it to start when required
if fail safe gear stops you from starting the thing then that, in my opinion, is anything but a contribution towards safety
D
the reason for the failure may be UV degradation. Do you leave the kill cord installed and the button uncovered when the o/b is on the stern ? It shouldn't happen, of course, but a spare tucked away under the hood or somewhere safe should be SOP.
Take the matter up with the maker. I think they will be surprised at the failure, especially if you can send them the remaining bits.
Can you pull the red button 'stem' out with a pair of pliers, and then secure it ?
The trouble is that everybody these days want things to be a cheap as possible.
Nobody wants to pay for quality.
Even when its available people look to ebay etc for cheap tat instead. ( I note your little picture is an ebay one)
What you experience is the result.
I bit of info on the above, the plastic cable ties, the smaller ones fit perfectly into the kill cord recess, I know it renders the kill cord inoperative until removed, but it does work if you are stuck. A lot of Greek hire boats have these in place because the punters lose the original or the sun degrades them! Not a perfect solution, but worth carrying one under the cowl.
as i understand it the button broke not the yoke thingy. a nice tohatsu 2 t would be better
The kill cord invention must have prevented countless injuries and crashes, worldwide, over the years though; a rare breakage is not a good reason to abandon (or even criticise) safety features, surely?
Which is more dangerous, an outboard that fails to start when you are in the boat, or one that fails to stop when you are out of it?
Should get a seagull
Dunno where Dylan posted that ...... there no reference or link back to it .... made up by 2nd apprentice perhaps
At least with a Seagull you can start it if the cord is lost or breaks and you have no spare bit of string to use in its place simply by spinning the flywheel between your hands.
They don't makem like they used to!
John G
OK in theory but in practice I very rarely see a kill cord attached on small dinghy engines, they're usually just hanging loose.
as is mine
a kill cord in a 2hp in an tiny inflatable is pretty irrelevant I think
the one on the Tohatsu which is the main boat engine in a well is completely irrelevant
safety gear imposed on all of us for the sake of the odd eejit
D
My 3.3 Evinrude never had a killcord fitted, so instead the sun buggered up my red plastic Stop button, I now switch the fuel off, or poke a screwdriver across the two terminals! keep on never minding.
