RJJ
Hello. Since leaving UK in July, virtually nothing has gone wrong. Too good to be true...
So I am after advice on facnor top swivel and any tips for a rigger in Cadiz or so.
So today we couldn't unfurl the jib; top swivel jammed. I went up to inspect; the swivel moves but is stiff; so I can turn it by hand but SWMBO couldn't operate under normal conditions from the cockpit (tried with halyard tension off and then on again).
I don't fancy shinning up the mast every time we want to fuel/unfurl the jib. So it looks as though I'm in for a new swivel. Before I do, is there any merit in dropping it and trying to resuscitate still on the foil? The top swivel does slide up and down and we could unwrap the sail on a calm day to do this.
As "luck" would have it we don't have time on our side given we are currently near Cadiz and need to get to Canaries for November. Thoughts on getting a replacement ordered and installed at best speed?? If anyone has a recommendation for a rigger locally it would be fabulous.
Thanks.
Thanks.
