external trunking for cables up the mast
catmandoo
21 Aug 2003
The Earth but normally in the place of the high st
I wish to run electriclal cables up the mast and do not want to run them inside . I understand that there are lengths of proprietary screw on trunking which can be attached to the outside of the mast to give a neat appearance . Can any one advise on the success of this method and on the best make to use ?
pvb
UK East Coast
Scanstrut...
Scanstrut have some special conduit in 2 sizes. Can be easier than messing about trying to get the cable down the mast; but doesn't look as neat.
Was common on wooden masts ... as they weren't hollow .. but generally the cabel was set in a shallow recess.
On an ally mast - take it this is an ally mast ? It would look awful IMHO .... but agree its much easier !!
?? Would putting so many small screw fixings in weaken the mast ??
MarkJohnson12345
23 Dec 2004
Swansea Wales UK
www.markjohnsonafloat.org.uk
I put external trunking up the mast for the radar cable.
Has the advantage that the radar can be demounted easily if ever the mast had to come down (no deck joint either)
Looks are not brilliant, but who notices it.
As for weakening the mast, a round hole shouldn't do too much damage, along with all of the other screws and rivets in it already.
regards
jfkal
17 Aug 2001
Singapore
Scanstrut. Expensive but good UV resistance. I Sikaflexed it on. Not a good idea to drilol holes in one line along the mast.
make sure you prime with the right primer, then it sticks forever.
