External Marine Instrument that will Display a Voltage ?
savageseadog
19 Jun 2005
I'm building a rig load indicator. I have a load cell, I will build a conditioner to output a voltage in proportion to load. I need a marine instrument that I could mount in a cockpit that can display in analogue or digital form the voltage. eg if there were an instrument that could display 0-10 for an input of 0-1V I could perhaps calibrate it to read 0-10 Tonnes. There is a vast range of marine instruments out there and someone on the forum hopefully might have some ideas. The other possibility is a converter that could take a voltage input and turn it into an NMEA or similar string. Any ideas please?
Most instruments have a voltage display, but it is the voltage in the supply to the instruments, and not discrete.
You could use a en ebay voltage display like this...
http://www.ebay.co.uk/itm/Waterproo..._Measurement_Equipment_ET&hash=item5af52b8d3a
which purports to be waterproof.....
Have you looked at the VDO range of marine gauges;
http://marine.vdo-gauges.com/
B&G make kit for exactly the use you are describing.
This is the simplest equipment you will need.
A loadcell amplifier/interface...
http://bandg.com/en-GB/Products/Loadcell-Amplifier/
A graphic display...
http://bandg.com/en-GB/Products/H3000-Graphical-Function-Display-GFD/
You could also use a smaller display like the 10/10 instead but you would have no means of configuring it in a minimal system. You would have to get a dealer to do it for you.
http://bandg.com/en-GB/Products/1010-HV-Display/
This lot make a loadcell with an integrated display...
http://www.diverseyachts.com/loadcells.php?t=LOADCELLS
Not related in any way. Well ok, I might be a bit. :)
The proper B&G stuff is eye wateringly expensive, this is very much a cheapo DIY job. There are some useful ideas here though so thanks so far.
If it's a"cheapo DIY job" get any cheap DVM and mount it inside a IP65 or better box with a polycarb lid.
Plastic cable glandes can seal any cables
