catmandoo
As you all probably know when you have multiple battery banks fed by alternator / alternators a battery isolator is interposed between the alternator and the batteries such that the charge is evenly distributed through out the banks with out one battery depleting another. This is done by arrangements of diodes in a box with fins for air cooling . Sure Power Inc is a major player in this field . Unfortunately the isolator imposes a voltage drop of about 0.7 volts which means that if the alternator regulator sense wire is local to the alternator outlet terminal then the regulator cuts out prematurely and does not charge the batteries fully etc .
To avoid this happening it is the practice to insert an external diode in the sensor wire such that the regulator sees 0.7 v less than the alternator out put voltage .
In my case I have a Valeo Motorola 70 marine alternator feeding a Sure Power isolator feeding 3 battery banks but unfortunately have lost the Motorola EK 300 diode which does this deception .
( a fast Sterling type 4 stage charging regulator is not considered in this query because I already have one and if it fails then i fallback on the alternators basic controls )
I am therefore looking for a replacement diode and wonder if any one knows where to get it or alternatively can advise what specification I should have when searching Maplin's catalogue to buy one
