Pumpkin
New Member
I had a new forestay made for my Leisure 17 last winter. Because the old one was a little tight I asked for the new one to be 2.5cm longer. Now the mast is up I find it (the mast) is now leaning ever so slightly forward and I suspect the rigger made the forestay 2.5cm shorter instead of longer. I don't really want to take the mast down so does anyone know of a simple way of lenghening the forestay by a couple of inches or so? There's Plastimo reefing gear fitted so things are a little congested at the base of the forestay. Would it be feasible to fit some kind of long shackle in between the chainplate and the forestay? In the Purple Marine catalogue there are things called "Strip Shackles - Rigging Links" that look suitable and are up to 51mm long. Are these what I need. Many thanks.
