electrosys
I seem to remember once having a 1 litre tube of Evostick Wood Adhesive that I used for several years - had to unplug the nozzle a couple of times, but it had a pretty good working life.
I recently discovered ToolStation's D4 Waterproof Wood Glue - only £6 for a litre. Well pleased. That is, until I came to use it last week, when half of the tube had turned to jelly. Only started using it 6 weeks ago. £6 for half a litre isn't quite so good.
The label says this stuff has a shelf-life of 6 months (from the date of manufacture), and must be stored between 15 and 25 deg C to attain this 6 months. Must not be used or stored below 10 deg C.
So - what we're talking about is a glue which can only be used during the summer, and the whole 1 litre must be used the same summer. Well that's ok if you've got a lot of wood to glue - bit of a waste if you're just jobbing with it.
Seems that glue 'ain't what it used to be ...' ?
