superheat6k
So having sorted my starboard engine's alternator, today I checked the drive was till tight after a 50 mile run. After a static inspection, I wanted to check for any signs of wobble under light load. The engine initially started then within a few seconds I heard a loudish click and the engine promptly stopped, then within a few more seconds the power to the engine instruments failed entirely.
The latter turned out to be a dodgy battery isolator switch, but when I restored power, whereas the engine would spin freely it refused to fire. I checked the stop solenoid which was quietly clicking as power was applied (power on to run), but the engine did not fire.
When it first stopped it was as though the engine had stopped on the stop solenoid as for any normal stop, although I do not recall hearing the click noise previously.
So it seems either the stop solenoid plunger has stuck in the stop position, the fuel lift pump has failed, or (worse case) something has snapped inside the fuel injection pump.
Further investigations commence in the morning.
Has anyone similar experience of a distinctive click noise when stopping a Cummins engine equipped with Lucas DPA type injection pump ?
