neil1967
I recently removed the exhaust cooling mixer elbow from my Perkins 4108 to check its condition. Having done so, I noticed that the manifold it's self, where it joins the elbow seems to have suffered Errosion/corrosion inside and that the first inch or so of the inside of the manifold is quite rough and irregular, although there is still plenty of metal there. The surface of the manifold where the exhaust elbow is bolted on to is fine, so i am not worried about exhaust gases leaking out. Is this just poor manufacturing (ie is it normal)? If not, is it worthwhile using a high temperature metal epoxy to restore the inside of the manifold, or should I just leave it? My concern with leaving it is that if I were to ever get any water going backwards into the manifold, it would accumulate there - or perhaps that is what caused it in the first place? If filling is a good idea, any suggestions for a suitable epoxy?
Neil
Neil
