Linguistine
New Member
Hi - regarding a Lister STW2
I have been searching for a blockage in this direct cooled engine for months and I 'think' that I have finally traced the problem to the feed through the exhaust manifold, a pipe runs from the thermostat to the manifold, through it and out the top and via a rubber pipe into the exhaust elbow. I have tried blowing through the top and bottom of this pipe and there is no flow, I currently have some Rydlyme filled to the top in a funnel/hose attached to the top of the manifold and there is pretty much no flow through, maybe a drip every hour. I want to check that this is the issue - I would have thought it would pour through from either way?
I have been told that I can bypass the wet exhaust and run the manifold hot - any thoughts/suggestions here most welcome.
Or, perhaps I should get the manifold taken off and soaked properly - it could be filled with sand etc? The set-up doesn't have a modern type of strainer just a cylindrical 'colander' in the seacock.
