Exhaust hose.
doug748
1 Oct 2002
UK. South West.
When I was away this summer I found the bilge full of water, to cut a long story short it was the exhaust hose leaking. It was not easy to patch, there is a lot of pressure in there. However that is by the by.
I am now renewing the hose.
Is it worth buying Vetus 51mm stuff at about £120 for the three metres - or is the ASAP Seaflow Superflex ok, at about half the cost?
I'm not specifically familiar with any of these hoses, but I would be entirely happy with either ASAP or Hyphose, both of whom I have bought a fair amount of other stuff from.
Used Halyard for last job. Very good as much more flexible than old style hose. Looked a Vetus which seems much the same. If ASAP is similar construction then should be OK.
I have just installed a short piece between my spanking brand new 3ym20 and the water trap. I bought it in Preveza. I am concerned how thin walled it is. About 2mm max 50 mm dia. The old hose is at least 7 mm wall. It was cut off with a hacksaw when T90 removed. Glad the rest of the hose is still in situ.
2mm does sound very thin but 7mm does sound very thick!
I have a bit of 51mm Vetus hose in front of me, the wall thickness is 5mm.
Thanks everyone, I have ordered new hose from ASAP.
Our new hose (Seaflow) has a thinner wall than the old hose, about 5 mm sounds about right. One benefit was that the overall O/D of the new hose, being smaller, made it a lot easier to thread past the various obstacles than anticipated.
