pmorris
Is there different qualities of exhaust hose? I think that it has to be lloyds approved , but what I was worried about was the flexability, (and cost). At the moment the system consists of a length of hose which drops below the engine and then rises to the top of the cocpit locker before descending to the skin fitting at the rear. In the last section as it begins to drop, its split and a rubberpeice is fitted in, which is about 6" in diameter 12" long and inside is a cone shape facing downwards with splits all around it, (I assume this is to restrict water being push up the hose in a following sea. Is this system ok or does it need a bit of modernisation
Also what are or where can I find the regulations for fuel systems. At the moment its just braided clear hose jubilee clipped onto small lengths of pipe screwed into the different component. ie. fueltank,lift pump, filter and injector pump. I imagine this isn't up to spec.
Thanks for any help, Paul.
