stav
Westerly conway with Mercedes om636 42hp.
I noticed whilst working on the oil pressure sender the rubber exhaust hose was showing signs of delaminating on the outer layers just down from where the water is injected. However the whole thing seems quite solid. Anyhow whilst in the UK bought 5M 2" diameter hose from hyphose in Poole whilst over in the UK for Xmas.
However feeling concerned about just changing it as the exhaust simple drops down from the engine then rises up with a small loop at the transom and then exits with no water traps or mufflers etc.
So should I leave it alone? Or what I was going to do was new pipe with a higher loop, but might the extra pipe introduce just a bit too much water and risk damage to the engine?
Or should I fit an exhaust water trap? Such as:http://www.asap-supplies.com/marine...centek-vernalift-inline-grp-waterlock-1500042
But I am not sure how much space there is but will have a look over the weekend whilst removing the injectors!
Finally at the moment it simply exits out of the stern via an elbow and skin fitting in the transom above the water line. But I was thinking about adding a 2" gate valve so it could be shut in extremes, but could I building a brass check valve in to the system,
http://www.ebay.co.uk/itm/BRASS-CHE...Domain_3&var=600054022656&hash=item4606e937bc
or would this give too much back pressure?
Any thoughts or ideas gratefully accepted. Just want to mention I am keen to change the exhaust as the kids play for extended periods in the aft cabin and have no idea of the age of the current hose and am concerned about it splitting and poisoning anybody in the cabin?
Thanks in advance.
Thanks in advance.
