gull1066
Hi All,
I brought a 1985 4hp twin cylinder outboard, which is in great condition. It runs fine but seemed to pump no water.
After checking the impellor and the water system all seems to be ok apart from there seems to be no water jetting out to indicate water circulation.
When i removed the leg from the main engine I did see that the water passes through the head then comes back out and seems to just drop down into the leg and out the holes low down. seems a bit strange as you would have no visable way of knowing if water is circulating. I can see no other way the water will can come out.
Is that right? Any advise would be good.
