tjfmmaes
I have an evinrude 4hp, 2 cyl, 2 stroke outboard, recently acquired, can't tell you the age but it is not new. As it was overheating, I dropped the drive unit to check the impeller, which was fine but the waterinlet was clogged up. Duly cleaned that and now it was time for re-assembly. That was last Sunday and I still haven't managed it. I know about the main tricks about holding it vertical, rotating the propeller until the drive shaft engages etc, but my main problem seems to be the gear linkage rod which will not engage properly into the gear box. I have tried doing this without the drive shaft and impeller housing and that, after some wiggling and achieving the right angle, worked i.e. the link rod slid in. With the driveshaft and impeller re-attached, however, it seems to be impossible as the driveshaft prevents me from getting the right angle and the impeller housing also prevents proper re-entry.
Any help and suggestions are greatly appreciated as summer seems to be leaving us fast and I'd like to get some enjoyment out of this.
Thomas
Thomas
