EVA Flooring -Quite Easy to use
Bigplumbs
7 Nov 2015
UK
We were quite fortunate and managed to buy a roll of this size 2.4 x 0.9 m delivered from the Range. it was only £19.99 but has gone up a tenner now. It is 3M adhesive so hopefully it will stay stuck.
Our little job was easy to the Ali floor of a Honwave T40 but you could obviously use it in all sorts of locations boating or otherwise. The curl is your biggest enemy
Certainly looks good.
Looking at it this morning there were a couple of edges that had raised up a bit. It is the damm curve from it being rolled in the box. I have put some heavy weights on it and they will stay there a while
I was thinking exactly the same. I use CT1 a lot. Heck that is sticky
+1 for CT1
I always consider that CT1 is to house builders what Sikaflex is to boat builders.
That said, I have found that this two part adhesive sticks the Trakmark synthetic decking down better.
I sourced this in Spain so I'm not sure where else it is available.
Well that was a scrabble. We decided to take the Honwave T40 out tomorrow with 2 friends and to my horror the edges of the EVA had curled. Not on the sides just the ends. My unopened CT1 Clear that I had in stock was no good so off I went to toolstation a got a new one. All I can say is if that comes unstuck I will eat the boat.
So the moral is if yours is a curler you will need to stick the ends well.
