vic008
Have done a bit of epoxy fairing on alloy mast. Does etch primer go over the top of epoxy ok, prior to painting.
He seems to have gone into hiding though.............
Thats the one, exactly. Was thinking the etch primer may react with the epoxy?I assumed that OP is painting his mast, has repaired some dings with filler, and wants to check that when he applies the etch primer to the aluminium, it will be Ok if he also applies (sprays?) it to the filler.
We're back to square one. Without knowing what products you are using it's anyone's guess. If the data sheets don't answer the question the best thing to do is to test some out on a spare bit of alloy.....you'll know soon enough if it isn't going to work.Thats the one, exactly. Was thinking the etch primer may react with the epoxy?
